July 19, 2023 at 12:10 am
h.al-wakeel
SubscriberHi,
To simulate a case of (Dual Fuel Combustion) from (Ansys Forte Tutorials), it is required a file named (Forte_bowl_geometry.stl). I searched online, but could not find it.
Please, can anyone provide me with this file?
Thanks
July 19, 2023 at 7:42 am
Forum ModeratorIs it not in the Help system?
July 19, 2023 at 11:22 am
h.al-wakeel
SubscriberNo, it is not provided with Help system. However, may be it is available in another place.
So, please can anyone provide me with the file named (Forte_bowl_geometry.stl)
Thanks
July 19, 2023 at 12:21 pm
Forum ModeratorYou are looking at this tutorial? https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/forte_tut/i469650165101.html The files are there and there is no stl needed.
July 19, 2023 at 12:35 pm
h.al-wakeel
SubscriberHi Rob,
Thank you for your prompt reply,
Yes, I am looking at this tutorial, but ithe first of all, it is required to (Importing the Mesh). So, how (or from where) can I import the geometry of Figure 3.1, please?
Thanks
July 19, 2023 at 12:53 pm
Forum ModeratorI'll check, but my assumption would be you copy the relevent bit from the project.
July 19, 2023 at 1:04 pm
h.al-wakeel
SubscriberYes, please check this tutorial. I am confused how to start and I am waiting your answer. Thanks for your help.
July 20, 2023 at 1:31 am
RK
Ansys EmployeeHello,
You should see the .ftsim file in the tutorial, load the file into Forte, then go to Geometry and Mesh > Export Geometry. You will have a stl file.
July 22, 2023 at 12:55 pm
h.al-wakeel
SubscriberThanks RK for your advice (Import Forte project, and then Export geometry)
- The topic ‘Forte_bowl_geometry.stl’ is closed to new replies.
5694
1891
1419
