Forte Mesh Information
    • mnjja
      how do I extract the mesh information ( i.e. number of cells, the size of cell, the number of non-convex cell) from the mesh generated using Forte Sector Mesh Generator, so I don't get cell inversion error when simulating.n
    • Rahul Kumar
      Hello, nThe max number of fluid cells occurs when the piston is at BDC. If you run such a case by starting at -180 deg ATDC, when the piston is at BDC, you can see the number of cells reported in FORTE.log. However, if you start the simulation from a different crank angle, then the cell count may be different due to snapping. For AMG cases as well, the fluid cells count is reported in FORTE.logn
    • mnjja
      Thank youn
  • The topic ‘Forte Mesh Information’ is closed to new replies.
