LS Dyna
LS Dyna
forrtl: severe (157): Program Exception – access violation
    • Emre Guney
      I encountered this error when I started a simulation.
      forrtl: severe (157): Program Exception - access violation
      There is no error in the message file.
      As seen below, I am getting a negative value related to the added mass.
      Could the problem be caused by this?
      If not, what could be the reason for this?
      Below are the timestep values I entered in the .k file.
      *CONTROL_TIMESTEP
      $#  dtinit    tssfac      isdo    tslimt     dt2ms      lctm     erode     ms1st
             0.0       0.9         0       0.0-3.2000E-7         0         0         0
      $#  dt2msf   dt2mslc     imscl    unused    unused     rmscl     emscl      ihdo
             0.0         0         0                           0.0                   0
      Thanks!
    • Andreas Koutras
      The error seems to be related to the contacts.
      Indeed DT2MS<0 is recommended over a positive value. If you specify DT2MS=0, does this error still occur?
      What is your LS-DYNA version?
      Thanks
      • Emre Guney
        Hello Andreas,
        Thanks for your feedback
        When I specify DT2MS=0 I get solution. However, the solution time is taking too long. (About 11 days). Previously, I determined DT2MS and solved similar projects(number of mesh, contact type, material etc.) within 1-2 days.
        My version of Ls Dyna is R11.2.2
  • The topic ‘forrtl: severe (157): Program Exception – access violation’ is closed to new replies.
