June 22, 2023 at 6:06 pm
June 23, 2023 at 10:48 am
Forum ModeratorPlease can you repost the image with node values off?Â
June 23, 2023 at 1:37 pm
SV
Subscriber-
June 28, 2023 at 4:37 am
June 23, 2023 at 1:43 pm
Forum ModeratorAnd with node values off?Â
June 23, 2023 at 2:05 pm
SV
SubscriberPlease let me know what you mean and how to do that?
June 23, 2023 at 2:43 pm
June 23, 2023 at 2:58 pm
June 23, 2023 at 3:05 pm
Forum ModeratorI was hoping for the contour as before. The droplet is probably shifted sideways by a combination of mesh and initial condition.Â
June 23, 2023 at 3:09 pm
June 23, 2023 at 3:23 pm
Forum ModeratorWhy do you think it's different?Â
June 23, 2023 at 3:29 pm
June 23, 2023 at 3:35 pm
Forum ModeratorRight, and looking at the above, why do you think it's behaving as it is? It's a sensible result, but one that's not quite as expected. Read up on the pitchfork bifurcation phenomena.Â
June 23, 2023 at 3:49 pm
SV
SubscriberÂ
I can see the issue here. When I was checking the existing clips, I see some people can model it correct. I tried to model axisymmetric (half of bubble) but I get error. I have injected air into water for case b experimentally and I have got axisymmetric bubble experimentally. I was wondering if you can guide me in a right direction. is there anything I can do to fix the issue.Â
June 26, 2023 at 7:56 am
Forum ModeratorAxi-symmetric will work fine, assuming you remember to scale the flow and follow the rules for axi-symmetric mesh/flow.
Asymmetry (or lack of) means you balanced a load of forces and had a perfect set up. In the experiments a slight nick in the entry port, off axis chamfer, spot of grease/fingerprint or fractionally higher flow could result in differences in the resulting bubble stream. In CFD the geometry should be good, but the mesh may be fractionally different, then there's multigrid etc. All tiny effects that can give a noticable effect.Â
Consider a balance scale, if perfectly balanced and add a 0.001g mass to one side. Tiny change, but we now have a huge difference in the result.Â
June 27, 2023 at 6:49 pm
June 28, 2023 at 11:18 am
Forum ModeratorDid you rotate the mesh, ie did you check the axis rules for 2d axi-symmetric?
June 28, 2023 at 12:42 pm
June 28, 2023 at 3:08 pm
Forum ModeratorPlease read the documentation for 2d axi-symmetric first.Â
June 28, 2023 at 5:28 pm
SV
SubscriberGreetings
I have modeled different Axi-symmetric (2D) before like fluid flow in a pipe. I double checked. I do not see any issue. Please send me a link if you want me to read or double check certain area.
Thank you
June 29, 2023 at 9:23 am
Forum ModeratorYou have gravity in the y direction, but the axis must be x=0. Hence checking.Â
June 29, 2023 at 12:55 pm
June 29, 2023 at 2:00 pm
Forum ModeratorThat'll explain the problem. Â https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_ug_GridQuality.htmlÂ
June 29, 2023 at 4:32 pm
SV
Subscriber -
June 29, 2023 at 5:03 pm
Forum ModeratorCheck the mesh - it's why I still want to see that plot with node values off. To tighten up the free surface you'll need good convergence and a well refined mesh.Â
- The topic ‘Formation of bubble by VOF’ is closed to new replies.
5779
