September 23, 2022 at 4:18 am
Marcin Milczarczyk
SubscriberHi all,
Can I make Foreshortened dimensions in drawing view in Spaceclaim? There is something about it in Help, but is not clear how this actually work.Â
Any advice?
Regards
September 23, 2022 at 4:21 am
Devendra Badgujar
Forum ModeratorHello Marcin Milczarczyk
I will check and get back to you.
September 23, 2022 at 4:52 am
Marcin Milczarczyk
SubscriberHi Devendra Badgujar
I did some future investigation. It seams to work only for radial dimensions. Can we get it on diameters and length dimensions also????? Solidworks do it without any problems (that doesn't means I am fan of SW :))Â
September 23, 2022 at 6:40 am
Devendra Badgujar
Forum ModeratorMarcin MilczarczykÂ
I am not sure if we can get foreshortened dimensions on diameters and length dimensions. Currently it seems to be only for radial dimensions. Â
I'll double check and let you know if there's any way to do it.Regards.
September 28, 2022 at 10:35 am
Devendra Badgujar
It is not possible to create foreshorten dimension on diameters and length dimensions at the moment. I will create an enhancement request for this functionality to be added.Â
Regards.
- The topic ‘Foreshortened dimensions in spaceclaim’ is closed to new replies.
5934
1306
