March 16, 2024 at 3:10 pm
Ella Chapman
SubscriberHi everyone,Â
I'm pretty new to ansys and I've been struggling to develop a simple forced convection solution (On Fluent). It's essentially a solid block within a domain that I've modelled as the fluid, but the problem is that there is no heat being produced? I have given a singular wall a heat flux while the others have been assumed adiabatic. Gravity is on, incompressible ideal gas for the density of air, SST k-omega. What have I done wrong?
March 18, 2024 at 10:39 am
Atharva Nagarkar
Ansys EmployeeHello Ella,
Please find the link below to an Ansys Course on setting up a turbulent forced convection problem. This course should act as a guideline for you to setup a forced convection problem. You may have to adjust some parameters and settings based on your case.
Turbulent Forced Convection | Ansys Innovation Courses
Additionally, I am attaching a link below from the Ansys User's Guide regarding forced convection. Please check the different sections if applicable.
15.2. Modeling Conductive and Convective Heat Transfer (ansys.com)
If you are not able to access the links, please refer to this forum discussion:Â Using Help with links (ansys.com)
Thanks!
March 18, 2024 at 10:46 am
Forum ModeratorNo heat anywhere, or no heat passing from the solid to fluid?Â
March 18, 2024 at 10:48 am
Ella Chapman
SubscriberYeah, I have no heat developing on the surface despite having a heat flux
March 18, 2024 at 11:29 am
Forum ModeratorWhat is the heat flux attached to? Please post some pictures as I'm running low of tea leaves, and the crystal ball is off for repairs! ;)Â
March 18, 2024 at 12:21 pm
March 18, 2024 at 1:34 pm
Forum ModeratorOK, I think I know what's going on. You didn't do share topology in the geometry tool (SpaceClaim), so have a nonconformal mesh. In itself that's OK (not ideal, but OK) but you've then added a wall heat flux to the connecting wall. If you're lucky the solid is warming up, but most likely nothing is getting warm.Â
The safest fix is to go back to the geometry step and ensure you've shared topology: that'll be covered in the tutorials and/or course on Learning. Mesh the geometry, please review the course/tutorials there too for some guidance.
In Fluent you need to decide where the heat is coming from. Ie is the whole solid hot (eg a computer chip) or is just one wall heated? The former is a source term, the latter a wall boundary condition (as you set in the above case). However... now you fixed the geometry you'll have a few wall & wall:shadow pairs (coupled walls) do NOT change that coupled setting without understanding what it does: it's covered in the Fluent User's Guide.Â
March 18, 2024 at 3:43 pm
Ella Chapman
SubscriberHi Rob, thank you so much for mentioning the topology, you've solved one of my issues that I was dealing with. However, even if I assume that the entire solid is hot, I'm still getting no heat.Â
March 18, 2024 at 3:54 pm
Forum ModeratorPlease can you post some images? Also do a heat flux balance on all surfaces.Â
March 18, 2024 at 4:02 pm
Ella Chapman
SubscriberHi Rob, I managed to fix it but thank you so much!!!!Â
- The topic ‘Forced Convection’ is closed to new replies.
5694
1891
1419
