July 10, 2025 at 7:28 am
nicolas.cuello
SubscriberHi all.
I would like to know if there is some way to extract the forces vs frequency in a random analysis.
I have solved a modal analysis first in my model and I have found the resonance frequencies, then i solved a random analysis. Now, i want to know the forces in several bolts conections (modeled with a 1D beam + MPC) in function of the frequency to study which frequecies have most impact in the bolts conections.
Is there a way in ANSYS Workbench or with some command in APDL to extract this information?.
Thanks.
Nicolás.
July 10, 2025 at 2:18 pm
dlooman
Ansys EmployeeYou mention MPC184, but it sounds like you want results for an ordinary beam element. If Mechanical is creating results for these elements (not a given), then you can use APDL commands like these:
/POST26Â
ESOL,2,Element_Number,,SMISC,1Â
RPSD,3,2Â ! Force RPSDÂ
/SHOW,PNGÂ
PLVAR,3
3477
1057
1051
945
912
