Force reaction in contact region-static structural
    • rouzbeh
      in my Static structural model, two rigid body press the spring between them, using remote displacement for rigid bodis. When I try to insert the reaction force probe and I choose the contact I want to explore, it's always stuck in the "question mark" signifier. the contact is frictionless. In analysis settings, under output controls, I set to save contact results and nodal forces, just save everything, so set all to yes, but it did not work.
      Does anyone know why the reaction force probe is not defined properly?
    • Ashish Khemka
      nnPlease clear the generated results and then resolve the analysis. This should help. If not then please share the snapshot of the Mechanical.nnRegards,nAshish Khemkan
  • The topic ‘Force reaction in contact region-static structural’ is closed to new replies.
