March 10, 2021 at 11:24 pm
isacco83
Subscriberhi, @peteroznewman i would like to ask your opinion
i have to apply the force of a pin inside a ring, the pin has the same diameter of the ring
March 11, 2021 at 2:01 ampeteroznewman
SubscribernUse a Bearing Load to apply the force and select the entire cylindrical surface.nA Bearing Load applies force to the surface only on the compression side of the hole.nA Bearing Load applies the highest force at the center and has a cosine drop-off to zero force at +/-90 degrees.nViewing 1 reply thread- The topic ‘force of a pin inside a ring’ is closed to new replies.
4909
1598
1386
1242
