April 21, 2024 at 12:29 pm
Adeleine Cabrera
SubscriberHi. I'm doing a transient structural analysis with thermal load (from transient thermal analysis) as a boundary condition. I have turned on Large Deflection. When I run the analysis without the thermal load, the solution and results are okay. But, when I analyze with the thermal load, there is a convergence problem and, based on 4 Netwon-Raphson, the problematic area is where the applied loads are. I have maximized the number of elements and nodes already and, I have tried increasing the substeps but it still doesn't work.
I actually did the same for other with the same geometry, engineering materials, and boundary coniditions but with a different thermal load. They worked but, not for one thermal load.
Can anyone help me to solve this? -
April 21, 2024 at 3:14 pm
peteroznewman
SubscriberHi Adeleine,
Check the coefficient of thermal expansion for all materials and make sure you use the correct units for temperature when you are entering a CTE value.
Check that all the materials and bodies are assigned the same reference/Environment temperature.
Try running the Static Structural model with a Thermal Condition and assign a 1 degree temperature increase to all bodies. For example, if the reference temperature is 20 C, assign a Temperature of 21 C to all bodies and see if you get a reasonable thermal expansion and reasonable stress values.
Peter
- The topic ‘Force convergence problem’ is closed to new replies.
- Contact stiffness too big
- Test post on Forum – LLM response – SC
- 13-Node Pyramid Element Shape Function
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
4502
1494
1376
1209
