January 23, 2024 at 5:47 am
akndnzmn
SubscriberHello,
I have a brief question. I want to find acting forces for specific points on a wall. I dont want to give name to the each wall because my domain is rotational and I need to split every wall into different sections. I tried to create points in SpaceClaim but since fluent didnt see the points, it didnt work. So is there any way to find forces on a points or specifid coordinate in fluent?
January 23, 2024 at 10:14 am
Forum ModeratorNot from the Force Reports as they need a surface (area) to function. You can report the pressure and use that.Â
January 24, 2024 at 5:16 am
akndnzmn
SubscriberHi Rob,
Thanks for your answer but there is a piston in the system that I need to calculate acting force on it to understand whether it slide right or left. So I think pressure results wont help much.
January 24, 2024 at 9:14 am
Forum ModeratorThen you need a surface. That can be a single facet so you can split a small section of the existing mesh to use for reporting. Have a look at mesh separate and (adaption) registers. However given pressure is force per area adjusting the values should work.Â
February 12, 2024 at 10:50 am
akndnzmn
SubscriberThanks for your help Rob.
- The topic ‘Force Calculation on a Specific Coordinate’ is closed to new replies.
5664
1890
1419
1304
