April 8, 2019 at 7:39 pm
Chandra
SubscriberHello everyone,
I am working on a model, where in multiple faces are present on that object.
Assumption :
I am applying force of 8000lbf onto the object having selected two faces. Does 8000lbf is equally distributed between those two faces or each face is applied 8000lbf.
Would appreciate, if you help me to clarify .
Thanks.
Chandra
April 9, 2019 at 11:47 am
peteroznewman
SubscriberThe force is distributed by the area of each face. So if the two faces have the same area, then the force is equal, but if one face has a larger area, that face will get more of the total force in proportion to the area.
April 9, 2019 at 12:38 pm
Chandra
SubscriberThanks Peteroznewman for your response.
It really helped me out. Thanks.
April 9, 2019 at 12:49 pm
jj77
SubscriberActually apdl which is the core (solver,..) of wb, will apply your force as an equivalent pressure, and thus as Peter means it will be sort of that the force in each face will be different if they have different areas since:Â Pressure/Face_Area.
Normally in structural engineering the pressure (wind load, snow load,..) is known and hence we apply a pressure, and that is anyhow what ansys does also, converts your force to pressure.
July 28, 2023 at 7:27 pm
Ron Leidl
SubscriberYou never really answered the question. Does each face get a pressure of 8000/A1 and 8000/A2 or does each face get a pressure of 8000/(A1+A2)?
July 29, 2023 at 2:58 pm
peteroznewman
SubscriberP = F/A = 8000/(A1+A2), assuming the two faces have the same normal direction which is parallel to the force.
- The topic ‘Force applied on multiple faces are equally distributed or not’ is closed to new replies.
