July 15, 2020 at 3:26 pm
zheyi95
Subscriberi want to simulate the tensile test on the composite material that i created myself
the speed of the testing is 5mm/min until it break
so as the image shown below, what value shall i key in to achieve 5mm/min?
as i know that time is not relevant to the input
so is it key in the x component “5“?
or function “5*time“?
thank you very much
October 21, 2023 at 12:49 pm
Desi Gustiani
Subscriber.
October 21, 2023 at 8:46 pm
Sampat Kumar
Ansys EmployeeHi zheyi95, This value would be 5 mm displacement. this would be the total displacement applied for the given time in the Ansys. Regards, Sampat -
October 22, 2023 at 6:16 am
Desi Gustiani
SubscriberHallo Mr Sampat, If you are willing can you help me? I really appreciate your help. I want to carry out a tensile test simulation with AISI 4140 material and compare with eksperiment result, actually I don't know the correct tensile test simulation process. Is there a video that you suggest or a discussion that I can learn from to carry out a tensile test simulation?
For the tensile test, does the Explicit Dynamic option use "Force" or "Displacement"?
Thank you so much Mr.
October 22, 2023 at 11:33 am
Sampat Kumar
Ansys EmployeeHi Desi,
You can type “ANSYS Tutorial: Tensile Test using Explicit Dynamics” in youtube and you can follow the tutorial.
please let me know if you have any queries related to this.
Sampat
- The topic ‘force applied for tensile test simulation’ is closed to new replies.
