March 20, 2024 at 11:58 am
Nikunj Panchal
SubscriberHello all,
I have the measurement data for Operational Vibration measurement for rotor running at different speeds e.g. 5000 rad/s, 10000 rad/s etc. and I want compare that to the simulation.ÂÂ
In the simulation I am using remote force to generate the Imbalance in the rotor and applying that for different frequencies.Â
Now I want to make sure that the force that is being applied in the simulation is for the speed of 5000 rad/s.Â
And I want the simulation to run for the range of 2000 to 10000(Because the measurement data that I have is for this range), which i can change in the Analysis settings by changing the range. I have already seen the documentation regarding this, there was a method using synchro command and also using the frequency sweep via variational technology Method, but I don’t think that really helps me in this situation and it doesn’t really clarify the doubt that I have.
Now the doubt that I have is
(1) I want to run the simulation between the range of 2000 to 10000 so I will have to provide the data for the force generated between this range, but the force that I want to apply is for a constant speed. So if I apply a different force for different frequencies that will increase the amplitude of force as well resulting in the increase of deformation amplitude.Â
So do I have to apply the same force for the whole frequency range? Or just apply the force at that specific frequency?
March 21, 2024 at 9:24 am
- The topic ‘Force application in harmonic response simulation for different speeds’ is closed to new replies.
3572
1118
1063
1055
952
