September 28, 2023 at 8:06 am
Muhammad Aditya Nugraha
SubscriberIn Simulation Example: Toy Drone Blade, why do we use pressure instead of force (just like another simulation examples befores)?
What is the difference between them?, In what conditions should we use pressure and force as a load condition? -
September 28, 2023 at 8:57 am
Raihan Lutfianto
SubscriberHi Aditya. A great question there. The first step is to think about the physics of them. The main differences between them are the MAGNITUDE of load and the DIRECTION of application.
Please take a look at this video Understanding the Difference Between Forces and Pressures Using Ansys Mechanical — Lesson 4 - YouTube
To answer your last question, we may consider using Force when we would like to model force acting on one part caused by other parts (generally the parts are not modeled). We can use pressure to model loads caused by fluids (assuming there is no shear forces by fluid)
- The topic ‘Force and Pressure’ is closed to new replies.
6765
1330
1102
