January 20, 2025 at 6:02 pmTim DukesSubscriber
I'm having trouble with a font in SpaceClaim and Discovery - The font is called Protrakt - https://www.freefontdownload.org/en/protrakt-regular.font
It creates a number of fonts in the systems. I'm not an expert on fonts but I belive it may be a 'variable font' is this the reason it doesn't work?
Tim
January 20, 2025 at 6:34 pmDeepakAnsys Employee
Is the issue specific to this font, or does it occur with any newly installed fonts?
-Deepak
January 21, 2025 at 4:51 amDevendra BadgujarForum Moderator
Hello Tim,Â
Are you seeing this in Discovery/SpaceClaim 2025 R1? This issue is not in the earlier versions right?Â
Devendra
January 21, 2025 at 9:33 amTim DukesSubscriber
Hi Devendra,Â
I haven't been able to test in 2025 but this is happening in in 2024R2 as you can see in the image below the font appears but separates into around 20 or so fonts and the preview you see on the right does not get used.Â
This issue is only with this font I have found I haven't tested with loads of other fonts.
I can send you the font.ttf file if you would like to take a look on your end?
Tim
January 21, 2025 at 10:06 amDevendra BadgujarForum Moderator
Hi Tim,Â
This is strange, it works fine at my end. Let us continue this through email.Â
DevendraÂ
- Unable to attach geometry 2024 R2
- Data Center Simulation
- Overlapping contact face
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Inventor 2025 files
- Issue Seeing Explore
- solidwork parameters for optimization in ansys
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- Fan flow simulation
1897
807
599
591
366
