December 27, 2023 at 6:44 pm
Seyyede Shahrzad Tabatabaei
SubscriberHello, I have a simple 1D beam created using "Static Structural" in ANSYS Workbench, and would like to find the deformation of the beam, under a "follower" line pressure. I want the distributed load (line pressure) to always remain perpendicular to the beam, throughout the deformation.
Thank you very much.
December 28, 2023 at 11:56 am
Aniket
Forum Moderator-
December 28, 2023 at 1:42 pm
Erik Kostson
Ansys EmployeeHi Aniket
This is for a local point/nodal force (follw201 element) and not a distributed line pressure application on a beam element – we do not have a way/load to apply a “follower” line pressure in mechanical. The line pressure in mechanical does not apply a follower pressure, it applies a pressure in a certain global direction.
Erik
December 28, 2023 at 2:41 pm
SubscriberThank you both very much for your responses. If I create many point loads along the length of the beam (uniformly distributed along the beam) to simulate a line pressure, and write the command Aniket shared, will the command apply to all the point loads? i.e., will all the point loads become follower type? I want the black point loads to be of follower type and the red load to be in constant y direction. Thanks
January 4, 2024 at 12:58 pm
Erik Kostson
Ansys EmployeeYou would need to modify that script given in the link shared above by Aniket – so that it will apply it to all the beam nodes.
Erik
February 21, 2024 at 5:31 pm
February 21, 2024 at 5:33 pm
Subscriber+ Considering my problem which is a beam under n number of loads (to simulate a pressure type force), I assume I need to define n number of remote points along the beam, apply n number of remote forces on them, and write n number of commands for each remote force, am I right?
And every time, I need to only change these for every remote force:
Thanks
- The topic ‘Follower line pressure (follower distributer load) in ANSYS WorkBench’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
4052
1482
