Electronics
Electronics
Flux direction issue
    • hameed
    • karthik.remella
      Administrator
      Hello,nI'm moving this post to the Electronics Sub-Category for better alignment. I hope this helps.nThanks.nKarthikn
    • karthik.remella
      Administrator
      For the benefit of all on the forum, this issue has been resolved here. n
      Hy I am working to simulate the axial flux permanent magnet machine i have design all the parameters of model and analyze the setup but the results are not according to standard i need pure sine wave having value in volts (5 to 10V)https://us.v-cdn.net/6032193/uploads/KENC7LM28TFB/15991150861822033420867.jpg with 90 degree phase shift in the induced voltage attaced figure has shape near to sine but value in mV i have set the mesh is ansoft classic and small analysis setup when i increase the setup size distortion in waves occurs. i have get flux linkage waves are accurate but the induced voltage have ripplesFigure are attached Please guideThanks ?/forum/discussion/20043/not-getting-pure-sine-wave-and-volatage-magnitude
      Thanks.nKarthikn
  • The topic ‘Flux direction issue’ is closed to new replies.
