May 13, 2024 at 2:39 pm
Akshatha Shivaraju
SubscriberHello,
We are trying to calculate the flux going through the lines on each rotor tooth. For that, we added the field density variable B, then when we try to take the real part of the vector we have an error "the stack contents are incompatible with the current operation". Normally the flux is the integration of the flux density following a line or a section. What is it that we are doing wrong?
Thank you in advance,
May 15, 2024 at 4:46 am
Harinath Vudumula
Ansys EmployeeHello Akshatha,
   Please follow below steps.
Please create a line across teethÂ
- Quantity > B
- X Form > To CylindricalÂ
- Click on Mag
- Geomrtey > Line> Select the line.
- Integrate it and evaluate or you can add to expression as Flux1.
Thank you,Â
Harinath Vudumula.
May 15, 2024 at 4:53 am
Harinath Vudumula
  The result of flux value will be for by default 1m length (in 2D) we have to multiply with (Actual length /1000)
Thank you,Â
Harinath Vudumula.
- The topic ‘flux calculation using field calculator’ is closed to new replies.
