April 12, 2024 at 3:39 pm
haibo
SubscriberI solved the structural dynamics and heat transfer of the structure with the Transient Structures Module, how should I post-process the thermal data of the model? I tried Ensigh and it didn't work out what I wanted.
April 12, 2024 at 3:49 pm
ErKo
Ansys EmployeeÂ
Hi
Can you explain a bit more and show some images of the workbench project and mechanical showing your model.
In that way forum members can provide some more feedback – so need more information.
All the best
Erik
April 14, 2024 at 2:50 pm
April 14, 2024 at 3:48 pm
Sampat Kumar
Ansys EmployeeHello HB Z,
You should use the coupled field transient analysis to calculate the temperature and heat flux distribution with the applied fixed support. You can also get the temperature and heat flux distribution by using transient thermal analysis, but you will not have the option to apply the fixed support in this case. Please try to chose the analysis type according to your requirement.Â
Best Regards,
Sampat -
April 15, 2024 at 6:36 am
ErKo
Ansys EmployeeÂ
Hi
Do not use any commands – this can be done natively. So solid226 you use with 11 keopt(1) are thermal structural.
For thermal + structural you need the coupled field transient system to do this natively.
All the best
Erik
- The topic ‘fluid-thermal-solid interaction post-processing’ is closed to new replies.
5664
1890
1414
1304
