February 9, 2024 at 10:05 am
Adamya Dhaker
SubscriberHello! i want to simulate a two-way, fully-coupled interaction between a highly deformable geometry (hyperelastic material- Neo-Hookean) and water. Basically, the movement of the solid body can be imagined as the propagation of a bend on a whip after you crack the whip. I want to see how this movement affects the flow physics, as well as study the forces applied by water on the whip. Is that possible in ANSYS? If yes, since the fluid domain won't be moving by itself, what would be the appropriate boundary conditions for it?
February 9, 2024 at 5:55 pm
My Wheels
SubscriberI had a confusion about this topic but in this post you clear it. honda 150f price in pakistan 2023
- The topic ‘Fluid-Structure Interaction for highly deformable geometry’ is closed to new replies.
