May 22, 2024 at 3:21 pm
haibo
SubscriberI used Workbench for fluid-structure interaction, but I found that the pressure data from the Fluent always does not converge from the log file of the System Coupling, why is this? Three coupling loops are set for each time step.
| COUPLING STEP = 192 Â Â Â Â Â Â Â Â Â Â Â Â Â Â SIMULATION TIME = 0.768 [s] |
|                   |    Source       Target     |
| Â Â Â Â Â Â Â Â Â Â Â Â Â COUPLING ITERATION = 1 Â Â Â Â Â Â Â Â Â Â Â Â Â Â |
| Transient Structural         |                    |
| Â Interface: interface-1 Â Â Â Â Â Â | Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â |
|   Data Transfer 2         |       Converged         |
|    RMS Change           |   4.28E-06      3.60E-06     |
|    Values Sum x          |   9.11E+04      9.11E+04     |
|    Values Sum y          |   -3.95E+01     -3.97E+01     |
|    Values Sum z          |   -1.01E+04     -1.01E+04     |
| Fluid Flow (Fluent) Â Â Â Â Â Â Â Â | Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â |
|   Data Transfer          |     Not yet converged       |
|    RMS Change           |   9.17E-01      9.29E-01     |
|    Values Average x        |   -7.77E-09     -8.27E-09     |
|    Values Average y        |   -1.06E-08     -1.14E-08     |
|    Values Average z        |   5.05E-08      5.24E-08     |
| Participant solution status     |                    |
|  Transient Structural        |       Converged         |
|  Fluid Flow (Fluent)        |     Not yet converged       |
| Â Â Â Â Â Â Â Â Â Â Â Â Â COUPLING ITERATION = 2 Â Â Â Â Â Â Â Â Â Â Â Â Â Â |
|    RMS Change           |   5.05E-06      4.44E-06     |
|    RMS Change           |   1.25E-01      1.28E-01     |
|    Values Average x        |   -8.41E-09     -8.99E-09     |
|    Values Average y        |   -1.00E-08     -1.07E-08     |
|    Values Average z        |   5.26E-08      5.49E-08     |
| Â Â Â Â Â Â Â Â Â Â Â Â Â COUPLING ITERATION = 3 Â Â Â Â Â Â Â Â Â Â Â Â Â Â |
|    RMS Change           |   4.00E-06      3.35E-06     |
|    RMS Change           |   9.79E-02      9.84E-02     |
|    Values Average x        |   -1.11E-08     -1.18E-08     |
|    Values Average y        |   -1.06E-08     -1.13E-08     |
|    Values Average z        |   5.88E-08      6.12E-08     |
May 23, 2024 at 6:35 am
Rahul
Ansys EmployeeThere are a number of convergence controls, you can try changing following controls:
‒ Default # of Coupling Iteration
‒ Data Transfer Under Relaxation Factor: 1
‒ Perhaps 5 Fluent iterations per Coupling Iteration (for transients), but this is case dependent; Before starting an FSI simulation, you should run separate fluids and structural simulations using representative loads and Use settings that are as close as possible to the planned FSI simulation.
‒ A Time Step Size based on the physics you need to resolve
• 1/20th of the oscillation period corresponding to the highest structural frequency of interest
• Flow field Courant number etc.Hope this helps!
- The topic ‘fluid-structure interaction’ is closed to new replies.
6004
