April 1, 2024 at 5:23 am
haibo
SubscriberI am going to simulate the fluid-solid-thermal interaction by Fluent, Transient Structure and the System Coupling. Can I make the time step size a function over time in the System Coupling, because one case about the FTSI takes too much time using fixed time step size such as 0.004s.
April 2, 2024 at 6:32 am
Rahul
Ansys EmployeeHello
Yes, you can make the time step size a function over time in the System Coupling using expressions like "0.2 if Step < 5 else 0.25".Â
Please refer to the System Coupling user guide for more information. Expressions in System Coupling (ansys.com)Hope this helps!
- The topic ‘fluid-solid-thermal interaction’ is closed to new replies.
