TAGGED: Ansys Discovery, fluid-thermal, thermal-conductance
February 5, 2025 at 7:07 am
antoniogutgon
SubscriberHi, reviewing the knowledge article ‘How to Specify different value of thermal conductance on Contact pairs ’ I was wondering whether or not it is really possible to put different values on fluid-solid interfaces?
I am unclear about the explanation given, which I underline below. I have tried it in an example and I don't think I was able to put different values.
Best,
Antonio
February 7, 2025 at 10:46 am
Charudatta Bandgar
SubscriberHello Antonio,
It means that, if there are multiple interfaces (separate fluid zones, being in contact with solids), different thermal conductance can be defined.
Charudatta B
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
1495
1386
1209
