November 1, 2017 at 9:40 pm
Tareq
SubscriberPlease I want to simulate a fluid to deal with it as a small particles, how can I do that?
November 1, 2017 at 9:48 pm
Raef.Kobeissi
SubscriberWhat type of fluid are you dealing with?
The discrete phase model (DPM) is one way to deal with discrete particles
Cheers -
November 1, 2017 at 9:56 pm
Tareq
Subscriberi have a non newtonian fluid move on a surface and need to study its properties at the end of movies but considering it as a particles.
how I am supposed to put the size of the paricles or what is the properties I have to add to make it as a particles not homogenous fluid?Â
November 1, 2017 at 10:04 pm
Raef.Kobeissi
SubscriberIf the fluid you’re talking about is the only fluid you’re using in the simulation it cannot be modeled as DPM because DPM is a way to inject discrete particles into a continuous fluid/domain. I am not sure why do you want to represent your fluid in a particle form. I don’t think you can achieve that.
Unless you want to visualise your streamlines in a particle form than this is different from actually simulating the fluid flow in particle florm.
There are methods to simulate fluids as particles such as smooth particle hydrodynamics but this is not CFD and it is not achieved by using ANSYS. These methods are usually used in 3D animations and they lack physical accuracy. -
November 1, 2017 at 10:49 pm
Tareq
Subscriberthe fluid is soldering material in form of sluid and to make the modelling more accurate we need to make the fluid simulated as a particles
November 7, 2017 at 12:50 pm
Raef.Kobeissi
SubscriberYou can use the DPM model in that case along side other models like solidification/melting but you have to remember that DPM should be within a continuous fluid domain.
Regards
Viewing 5 reply threads
- The topic ‘Fluid simulated as a very small particles’ is closed to new replies.
