April 20, 2020 at 9:19 am
joeargar1
SubscriberWould anyone be able to help with the correct boundary condition inputs? I have a 20mm x10mm fluid domain with a 10x10 lattice structure in the middle of it. I need to apply an air velocity through the inlet and through the panel to cool the air down. At the minute, the air temperature is changing before it has reached the lattice panel. Any suggestions?
April 20, 2020 at 9:42 am
DrAmine
Ansys EmployeeCan you a sketch describing the case you want to model?
April 20, 2020 at 9:50 am
April 20, 2020 at 5:12 pm
DrAmine
Ansys EmployeeAnd how are accounting for vapor release out of the lattice? -
April 22, 2020 at 10:13 am
joeargar1
SubscriberHi, i'm not too sure to be honest with you. I have a very low understanding of using ansys. Have you got an email address that I could send a couple of questions too if possible and also the link to my ansys document for you to have a look? Thanks for the help.
All the best,
Joe
Viewing 4 reply threads
- The topic ‘Fluid Fluent’ is closed to new replies.
