November 6, 2017 at 2:54 pm
Ivy.s
SubscriberI want to simulate a screw through which cement (with a viscosity of 1000 Pa*s) flows. In the following pdf document you can see what i want to simulate.Â
My problem is, that the cement flows through the holes of the screw (which is correct) but after that it flows upwards on the outside of the screw. I enabled gravity, but that did not help. I don't know if i used the wrong model for that or what's wrong with my simulation. Please help me.Â
In the pictures you can see the settings of my simulation, i hope you can help me with this.
phase 1 = air
phase 2 = high viscosity liquid
November 6, 2017 at 2:56 pm
November 6, 2017 at 3:43 pm
November 6, 2017 at 4:02 pm
peteroznewman
Subscriber@Rahul, in the Structural Mechanics side of ANSYS, I use an acceleration of x = -9.81 m/s^2 to create the effect of a gravity force that pulls mass in the +x direction as shown in the last snapshot. I'm not an expert at Fluent, but I would assume it would be the same.
November 6, 2017 at 4:58 pm
raul.raghav
Subscriber@peteroznewman, I'm quite sure in Fluent and CFX its not the same way. The definition of gravity depends on the coordinate system.
Please see the tutorial below and the attached screenshot to get an idea of how gravity is accounted for (under Step 2: Models).
Fluent Tutorial: Using the Eulerian Granular Multiphase Model with Heat Transfer
November 7, 2017 at 7:00 am
Ivy.s
SubscriberI've already tried to Change the gravity into +9.81 but the result is the same. And I also edited it in the "General" tab. I just forgot to make a screenshot of it.
November 7, 2017 at 2:55 pm
raul.raghav
SubscriberNot sure what could have gone wrong. Would you be able to share your mesh file by any chance?
November 9, 2017 at 8:25 pm
Ivy.s
Subscriber -
November 10, 2017 at 10:28 am
Raef.Kobeissi
SubscriberJust a quick comment. You need to have your acceleration as +9.81m/s2 in the X dirextion otherwise your gravitational acceleration is wrong.
From the picture you posted it seems the flow is reaching a wall and being squeezed upward or seeping through a hole. You need to check your geometery and mesh for any anomalies. -
November 10, 2017 at 11:32 am
Ivy.s
SubscriberI changed the gravity now to +9.81 m/s²
The result is the same. The liquid flows upwards outside of the screw.
It is correct, that the liquid is being squeezed through the holes of the screw, as you can see in the following picture.
But I don't understand why it flows upwards after that. In reality it flows a bit upwards as well, because of the pressure that squeezes the liquid out of the holes, but not that much. Most of the liquid must flow downwards because of the gravity.
November 10, 2017 at 11:36 am
Raef.Kobeissi
SubscriberIt depends on your geometry, when you rectified your gravity acceleration have you restarted the simulation? Can you share the pressure and velocity contour in your simulation please.
Cheers -
November 12, 2017 at 9:42 am
November 12, 2017 at 10:22 am
Raef.Kobeissi
SubscriberHello, from the contours you just showed it looks like you have high differential pressure and I believe the flow behaviour upward despite gravity is perfectly normal due to high pressure and flow deflection.
Regards -
November 12, 2017 at 10:55 am
Ivy.s
SubscriberDo you know how I can set the pressure down, to test if the result is better with a lower pressure?
November 12, 2017 at 1:40 pm
Raef.Kobeissi
SubscriberYou can use inlet pressure instead of velocity inlet, this way you can set the pressure at whatever value you want but you wont be able to control the velocity.
- The topic ‘Fluid flows upwards despite the fact that gravity is enabled’ is closed to new replies.
5889
1306
