Fluid flow through the nozzle
    • Sohanur Rahman
      I am trying to draw a 2D nozzle with the help of Ansys spaceclaim 2023 R1. I have drawn one side of the nozzle through equation. So when i am trying to draw another side, drawn one get vanished. I don't find any green tick to fix my already drawn portion. Then how do i draw the whole nozzle by using different equation at a time?
    • rahul.kumar
      If the curve is same, you can just mirror the curve along the center line. If not, generate one curve, get out of the sketching mode and try generating another.
    • Sohanur Rahman
      Thank you. But i have tried these ways. Unfortunately, the drawn part get vanished whenever i am trying to draw center line to mirror the curve. Same thing happens when i am trying to get out of the sketching mode. How do i solve this problem? Another question is , is it possible to use the same equation to draw the curve in design modeler?
    • rahul.kumar
      I just tried this... Create a curve with an equation, click on the green check mark and press esc (to come out of the equation mode).
      Then, go to the equation tool to create another curve or any other sketch
  • The topic ‘Fluid flow through the nozzle’ is closed to new replies.
