August 17, 2017 at 6:11 pm
svecchi
Ansys EmployeeIn this tutorial, the velocity vectors and pressure profile will be simulated in an S-duct. The flow volume has been provided. Flow will enter the large volume upstream of the S-duct and exit from the end protruding from the large volume. The pressure at the inlet will be 88744 [Pa] and the outlet will be supersonic. See the attached file for the tutorial.
March 5, 2018 at 2:38 pm
- The topic ‘Fluid Flow – Flow in a S-Duct’ is closed to new replies.
