March 7, 2024 at 2:17 pm
pclech
SubscriberHello.
I have a problem of conflict between a volume of air in a box and the surface of a heating element in the box.
I have this messages as follows:
The conflit is here:Â
I understand that I have a conflict there but I don't understand how to resolve it.
Can anyone help me?
Thank you in advance.Philippe.
March 8, 2024 at 5:52 am
Devendra Badgujar
Forum ModeratorHello Philippe,Â
You can try imprinting to split those surfaces. Imprint tool is available in the Prepare Tab.Â
Let me know if this helps.Â
Thanks,
Devendra
March 8, 2024 at 7:16 am
March 8, 2024 at 7:49 am
Devendra Badgujar
Is the heat BC set on the surface or on body? Try setting up heat on body instead of the face and check.
Thanks,
DevendraÂ
March 8, 2024 at 8:19 am
March 11, 2024 at 9:13 am
Devendra Badgujar
Forum ModeratorHello,Â
Is the Temperature on the same body or on the surfaces here?Â
DevendraÂ
March 11, 2024 at 9:18 am
Viewing 6 reply threads
- The topic ‘Fluid Flow: Conflict between two volumes’ is closed to new replies.
