March 16, 2023 at 5:54 pm
Francesc Riera
SubscriberHi, I wonder if it is possible to simulate the response that a fluid (like water) enclosed in an elastic solid would have to an external pressure applied on the external surface of the solid. Is this possible? And if it is possible, how should I proceed?
Thanks.
March 17, 2023 at 12:05 pm
Forum ModeratorIt is, but what would it prove?Â
March 20, 2023 at 11:07 am
Francesc Riera
SubscriberI am trying to see if the fluid inside can reduce the pressure applied to the fluid-solid system and how does the viscosity of the fluid affect this reduction. How could I simulate this? With a two-way FSI analysis?
Thanks.
March 20, 2023 at 1:41 pm
Forum ModeratorAre you expecting the fluid to flow? There are fluid elements in Mechanical so you may be able to model the whole lot there. Otherwise, there is an intrinsic FSI function in Fluent that may be sufficient. It's dependent on the level of deformation.Â
March 20, 2023 at 5:21 pm
Francesc Riera
SubscriberThanks rob, my intention is that there is no flow, but that way is it possible to take into account the fluid viscosity? Sorry I'm new in Ansys and I don't how can I simulate this fluid-solid system on mechanical.
March 21, 2023 at 9:48 am
Forum ModeratorIf you need to account for viscosity you may want FSI, click on Help in Fluent and you'll find the documentation, tutorials and videos. Also review the fluid elements in Mechanical - I have no idea how that works though.Â
- The topic ‘Fluid enclosed in a solid simulation’ is closed to new replies.
5814
