July 21, 2019 at 11:10 pm
UJSOB
Hi everyone, i have this problem every time I try to start the Set Up in my project it does it but at the end, the error message shown in the first image pops-up and then when i try to close the page the second error message comes up, what should i do. I already restarted my computer and also worked on the project since the beginning and the problem persist. Thanks for your help, have a nice day
July 22, 2019 at 12:06 am
UJSOB
SubscriberProblem solved, as Spanish is my natal language i use in most of the names of my folders, when required, the " ´ " which is a grammatical symbol, the mentioned before causes an error when ANSYS is looking for the correct folder as it is unable to read such symbols, the same happens in any other languages that tend to use special symbols, so just avoid so when working in ANSYS and its associated file folders. Have a nice day!
July 22, 2019 at 4:48 am
Amine Ben Hadj Ali
Ansys EmployeeKind of you posting the solution
- The topic ‘Fluent_Set up_error’ is closed to new replies.
4989
1670
1386
1243
