Ansys Products
Ansys Products
Fluent Watertight Geometry Meshing Workflow error in CAD import
    • MG
      Hi expert,
      I'm having a problem meshing the geometry I drawned in the spaceclaim, It works in the import geometry, and local Sizing but it gives error in CAD import when generating mesh. I did different model but still thesame. My last resort is to call my school IT to reinstall it which I don't want it.
    • Federico
      is this issue model specific? Are you able to generate a mesh with any other CAD?
      The Watertight geometry worfklow imports your CAD files and converts it into a .pmdb. The latter file is the one that is used to generate the mesh. If the issue persist with any CAD, then there might be an issue with the CAD configuration for .pmdb
    • MG
      Hi Federico It is not model specific becuase i tried to mesh with the other mesh software in workbench and its works. I tried other models and it is thesame. Im wating for our IT to reinstall to see if it will solve the issue. Thanks
