February 12, 2020 at 4:51 pm
Fremol
SubscriberI'm using ANSYS 19.2 academic version. I'm simulating disk sprayer with wall UDF.
I use the code directly from fluent UDF manual.
I compiled using VS 2017 prompt.
No problem in the initialization step.
But when I run calculation it displays the following error.
""No error handler available
Error: Cortex received a fatal signal (unrecognized signal).
Error Object: ()""
February 13, 2020 at 12:03 pm
Forum ModeratorAnything else in the TUI? If you copied the code directly from the manual check for white space characters, HTML tends to be full of them.Â
February 20, 2020 at 7:57 am
Fremol
SubscriberThanks rwoolhou.
March 2, 2021 at 1:45 pm
Darry6682
SubscriberI have the same problem. nANSYS 19.2, VS 2012, well-ran UDFs from other computersnget n''Error: Cortex received a fatal signal (unrecognized signal).nError Object: ()nnError: %cx-set-label: wta[1](widget)nError Object: #f''nwhen I hit the calculationnAny help would be appreciated.n -
March 2, 2021 at 4:47 pm
Forum ModeratorWhat does the UDF do? Widgets are the terms used for the GUI panels. n -
March 2, 2021 at 10:22 pm
YasserSelima
SubscribernDid you compile the code on the current computer?n -
March 3, 2021 at 9:45 am
Darry6682
SubscriberThanks for your attention! I ran the fluent 15.0 before but it happened to stall at the first iteration (as shown in the figure below)when I hit the calculation last week (before that I could run my case fluently). So I supposed that the version I use is quite low or the computer is overloaded and therefore I installed the Ansys 19.2 and simplified the mesh elements from 240w to 150w. However, the case in fluent 19.2 has not been successfully run once.nI load three UDF in this case. One is to improve the K-e model and provide sheared wind profile and another two are to model the wind turbine with VBM (virtual blade model).I didn't compile the code on the current computer and just compiled them in fluent. Again, this setting has been successfully run on my old version of fluent, it just happened to stall one day.nnThanks for your help. Darry
March 5, 2021 at 1:49 am
Darry6682
Subscriberyes, of course. Here it is.nnDEFINE_ADJUST(SrcComp,domain)n/*
*/n/*tttt    tttt    */n/*tttt    tttt    */n/*VersiontDatetNametttRemarkst    t    */n/*
*/n{nn#if !RP_HOSTn int i, count, count_max;n Thread *tc = NULL;n cell_t cc;n real *factor_ptr, sum_area;n real r_pb,psi_pb,r_pb2;n real Ux_pb,Uy_pb,Uz_pb;n real Usc, Utc, Unc, aeps, Utotal, beta;n real theta, chord;n real CL, CD;n real Ftc, Fnc, Fsc;n real FL, FD;n real Fx, Fy, Fz;n real *xsource_ptr, *ysource_ptr, *zsource_ptr;n real *xsource_old_ptr, *ysource_old_ptr, *zsource_old_ptr;n real Re_t, Ma_t, alpha_t;n real thrust, Fz_pb, CT;n real x_pb, y_pb, Mx_pb, My_pb, CMX, CMY;n int flag_jac;n real ct_s, ct_h, ct_l, bcop_l, bcop_s, bcop_h;n real cmx_lc, cmx_ls, cmx_s, cmx_hc, cmx_hs;n real cmy_lc, cmy_ls, cmy_s, cmy_hc, cmy_hs;n real bcyc_l, bcyc_s, bcyc_h, bcys_l, bcys_s, bcys_h;n real ct_lc, ct_ls, ct_hc, ct_hs, cmx_l, cmx_h, cmy_l, cmy_h;n real alpha_tmax, alpha_tmin;n real torque, power, Ft_pb;n real sum_thrust, sum_Mx_pb, sum_My_pb, sum_torque;n real max_alpha_tmax, min_alpha_tmin;nn /*Domain *domain;*/n domain = Get_Domain(1);nnn Message0(%d In DEFINE_ADJUST - SrcComp \,myid);nn /*Loop through all zones*/n i=0;n while (i < nrtz)n {n  Message0(%d Rotor %d \,myid,i+1);nn  tc = Lookup_Thread(domain,czon);n  factor_ptr = Get_Thread_Memory(tc,factor);n  xsource_ptr= Get_Thread_Memory(tc,xsource);n  ysource_ptr= Get_Thread_Memory(tc,ysource);n  zsource_ptr= Get_Thread_Memory(tc,zsource);nn  xsource_old_ptr= Get_Thread_Memory(tc,xsource_old);n  ysource_old_ptr= Get_Thread_Memory(tc,ysource_old);n  zsource_old_ptr= Get_Thread_Memory(tc,zsource_old);nnntcount=0;n  begin_c_loop_int(cc,tc)n   count++;n  end_c_loop_int(cc,tc)n  count_max=count;n  /*Message(count_max %d,count_max);*/nntflag_jac=0;n  LABEL1:nt thrust=0.0;nt torque=0.0;nt Mx_pb=0.0;nt My_pb=0.0;n   sum_area=0.0;nt alpha_tmax=-1000.0;nt alpha_tmin=1000.0;n   count=0;nn   begin_c_loop_int(cc,tc)n    get_radial_position(i,cc,tc,count,count_max,&r_pb,&psi_pb,&r_pb2,ntt           &x_pb,&y_pb);n    /*Message0( r_pb %f   psi_pb %f x_pb %f  y_pb %f \,ntt  t  r_pb, psi_pb*180/M_PI, x_pb, y_pb);*/nnt  vel_xyz_to_blade(i,cc,tc,count,count_max,psi_pb,r_pb2,ntt  t       &Usc,&Utc,&Unc,&aeps,&Utotal,&beta,&Ux_pb,&Uy_pb,&Uz_pb);n    /*Message0( Usc %f Utc %f Unc %f \,Usc, Utc, Unc);*/ntt/*Message0(aeps %f \, aeps*180.0/M_PI);*/nnt  get_pitch(i,cc,tc,count,r_pb,psi_pb,&theta);n    /*Message0( psi_pb %f theta %f \,psi_pb*180/M_PI, theta*180/M_PI);*/nn    get_chord(i,cc,tc,count,r_pb, &chord);ntt/*Message0(%f \,chord);*/nnttget_re(i,cc,tc,count,chord,Utotal,&Re_t);ntt/*Message0(  Re_t %f \,Re_t);*/nnttget_ma(i,cc,tc,count,Utotal,&Ma_t);ntt/*Message0(  Ma_t %f \,Ma_t);*/nnttget_aoa(i,cc,tc,count,aeps,theta,&alpha_t);ntt/*Message0(  alpha_t %f \,alpha_t*180/M_PI);*/nnttget_cl(i,cc,tc,count,r_pb,Ma_t,Re_t,alpha_t,&CL);ntt/*Message0(  CL %f \,CL);*/nn    get_cd(i,cc,tc,count,r_pb,Ma_t,Re_t,alpha_t,&CD);ntt/*Message0(  CD %f \,CD);*/nnttget_force(i,cc,tc,factor_ptr,&sum_area,sum_area,count,count_max,ntt      CL,CD,chord,aeps,Utotal,r_pb,&Ftc,&Fnc,&Fsc,Ux_pb,Uy_pb,Uz_pb,&FL);ntt/*Message0(Ftc=%f Fnc=%f Fsc=%f \,Ftc, Fnc, Fsc);*/nn    force_blade_to_xyz(i,cc,tc,count,Ftc,Fnc,Fsc,beta,psi_pb,ntt  t        &Fx,&Fy,&Fz,&Fz_pb,&Ft_pb,FL);ntt/*Message0(Fx= %f Fy= %f Fz= %f Fz_pb= %f \,Fx, Fy, Fz, Fz_pb, Ft_pb);*/    if (flag_jac == 0) get_source_terms(nttt         i,cc,tc,count,xsource_ptr,ysource_ptr,zsource_ptr,nttt         xsource_old_ptr,ysource_old_ptr,zsource_old_ptr,nttt         Fx, Fy, Fz, urf_source);nnttthrust=thrust+Fz_pb;nttMx_pb=Mx_pb+Fz_pb*y_pb;nttMy_pb=My_pb+Fz_pb*x_pb;n    torque=torque+Ft_pb*sqrt(x_pb*x_pb + y_pb*y_pb);nnttalpha_tmax=max(alpha_tmax,alpha_t);nttalpha_tmin=min(alpha_tmin,alpha_t);nnt  count++;n   end_c_loop_int(cc,tc)nnn   /*Message(  sum_area %f \,sum_area);*/n   sum_thrust = PRF_GRSUM1(thrust);n   sum_Mx_pb = PRF_GRSUM1(Mx_pb);nt sum_My_pb = PRF_GRSUM1(My_pb);nt sum_torque = PRF_GRSUM1(torque);n   max_alpha_tmax = PRF_GRHIGH1(alpha_tmax);n   min_alpha_tmin = PRF_GRLOW1(alpha_tmin);nn   get_ct(i,sum_thrust,&CT);n   get_cmx(i,sum_Mx_pb,&CMX);n   get_cmy(i,sum_My_pb,&CMY);nnnt if (flag_jac == 0)nt {n    power=sum_torque*rspe;nnttMessage0(  %d Rotor %d Thrust %f ct= %f \,myid,i+1,sum_thrust,CT);ntt/*Message(  %d Rotor %d Thrust on node %f \,myid,i+1,thrust);*/n    Message0(  %d Rotor %d Torque %f \,myid,i+1,sum_torque);n    /*Message(  %d Rotor %d Torque on node %f \,myid,i+1,torque);*/nttMessage0(  %d Rotor %d Power %f \,myid,i+1,power);nttMessage0(  %d Rotor %d Mx_pb %f cmx= %f \,myid,i+1,sum_Mx_pb,CMX);n  t/*Message(  %d Rotor %d Mx_pb on node %f \,myid,i+1,Mx_pb);*/nttMessage0(  %d Rotor %d My_pb %f cmy= %f \,myid,i+1,sum_My_pb,CMY);n  t  /*Message(  %d Rotor %d My_pb on node %f \,myid,i+1,My_pb);*/nttMessage0(  %d Rotor %d Max AOA %f \,myid,i+1,max_alpha_tmax*180/M_PI);n tt/*Message(  %d Rotor %d Max AOA on node %f \,myid,i+1,alpha_tmax*180/M_PI);*/nttMessage0(  %d Rotor %d Min AOA %f \,myid,i+1,min_alpha_tmin*180/M_PI);n tt/*Message(  %d Rotor %d Max AOA on node %f \,myid,i+1,alpha_tmin*180/M_PI);*/nt }nnnt update_trimming(i, trufq_co, trufq_cy, trdf_co, trdf_cy,nttt      up_co, up_cy, CT, &flag_jac,ntttttt&ct_l, &ct_s, &ct_h,ntttttt&bcop_l, &bcop_s, &bcop_h,nttttttCMX, CMY,n            &cmx_lc, &cmx_ls, &cmx_s, &cmx_hc, &cmx_hs,ntttttt&cmy_lc, &cmy_ls, &cmy_s, &cmy_hc, &cmy_hs,ntttttt&bcyc_l, &bcyc_s, &bcyc_h,ntttttt&bcys_l, &bcys_s, &bcys_h,nttttt  &ct_lc, &ct_ls, &ct_hc, &ct_hs,ntttttt&cmx_l, &cmx_h, &cmy_l, &cmy_h);nnn   if (flag_jac == 1 || flag_jac == -1 ||ntt flag_jac == 2 || flag_jac == -2 ||ntt flag_jac == 3 || flag_jac == -3) goto LABEL1;nnn  i += 1;nn }n istflag=0;n#endif -
March 5, 2021 at 3:44 am
YasserSelima
Subscriberwhat was the last message printed before the error?n -
March 5, 2021 at 7:13 am
Darry6682
Subscriberthe last message indicates that I have loaded the VBM model successfully.
March 5, 2021 at 7:33 am
DrAmine
Ansys EmployeeDo you the compiled VBM UDF library only? Or the Source too?n -
March 5, 2021 at 9:22 am
Darry6682
SubscriberYes, I have the source in the libudf too. The libudf folder has two folders, namely src and win64.
March 5, 2021 at 10:49 am
- The topic ‘Fluent udf error’ is closed to new replies.
3647
1313
1142
1069
1013
