October 11, 2024 at 2:29 am
yaolong1302091233
SubscriberHi everyone, I'm having problems using FLUENT for stirring simulation again, UDF moving mesh + MIXTURE, and when I run it, I often get a mistake
Updating solution at time levels N and N-1.
Updating solution at time levels N and N-1. done.
Updating mesh at time level N...
set_part_dest_tree: cell not found on myid = 7.(Fig.3)
This makes the calculation impossible and I have to proceed from the latest saved transient casdat file, which is obviously frustrating, I would like to know the reason for the error and a possible solution, is it related to the parallel core settings, when I open Flunet to work on it, I always get the message, Process affinity not being set (Fig.2)? I am using 50 cores double precision for simulation work. From the iteration curve(Fig.1), i dont think it is a mesh problem or model issue. hope you guys can answer my query, thanks! -
October 11, 2024 at 8:56 am
Forum Moderatorhttps://innovationspace.ansys.com/forum/forums/topic/fluent-udf-dynamic-mesh-mixture/Â Does this help?
- The topic ‘FLUENT UDF dynamic mesh+ MIXTURE’ is closed to new replies.
4728
1565
1386
1242
