April 11, 2024 at 12:05 pm
315914335
SubscriberHi, guys. Recently, I plan to define pre-exponential factors for limited rate reactions through UDF. The UDF can be compiled and mounted, but the reaction cannot proceed. Hoping to get the reason? The reactant is kerosene. The UDF code is as follows:
include "udf.h"
DEFINE_VR_RATE(rate_bfer,c,t,r,wk,yk,rate,rr_t)
/*If more than one reaction is defined, it is necessary to distinguish
between these using the names of the reactions. */
  if (!strcmp(r->name, "reaction-1"))
    real ci, prod, er, pef_1;
    int i;
    er = (yk[r->reactant[0]] / wk[r->reactant[0]]) / (fabsf(yk[r->reactant[1]] / wk[r->reactant[1]]) + 1e-9);
    pef_1 = r->A * er;
      /* Calculate Arrhenius reaction rate */
    prod = 1.0;
    for(i = 0; i < r->n_reactants; i++)
      ci = C_R(c,t) * yk[r->reactant[i]] / wk[r->reactant[i]];
      prod *= pow(ci, r->exp_reactant[i]);
    *rate = pef_1 * exp(- r->E / (UNIVERSAL_GAS_CONSTANT * C_T(c,t))) * prod;
    /* without pow(C_T(c,t), r->b)*/
    /* *rr_t = *rate;*/
  /* Reaction 1 */
  else if (!strcmp(r->name, "reaction-2"))
    real ci, prod, er, pef_2;
    int i;
    pef_2 = r->A * er;
    prod = 1.0;
    *rate = pef_2 * exp(- r->E / (UNIVERSAL_GAS_CONSTANT * C_T(c,t))) * prod;
    /* *rr_t = *rate;*/
  /* Reaction 2 */
April 11, 2024 at 2:17 pm
Forum ModeratorIf you add some message lines into the UDF are they triggered? You need to figure out if the UDF is doing something unexpected re the maths or if it's not working at all.Â
April 11, 2024 at 2:21 pm
315914335
SubscriberI don't think the udf is working so I'm hoping to find the way to make it work. Any suggestions?
April 11, 2024 at 2:27 pm
Forum ModeratorAdd in some messages to see if it's triggering but not doing anything or not triggering etc.Â
- The topic ‘Fluent UDF DEFINE_VR_RATE unable to react’ is closed to new replies.
