October 9, 2019 at 8:27 pm
rafa08
SubscriberI am having issues to set the time stepping of my simulation, i am trying to use a variable time stepping method and i have choose CFL based. my problem is the time step change just when the simulation start, but once it gets the minimum time step size it keep fixed in that even though the max convective courant number is way lower than 0.8.
Thanks for anyone's help!
October 10, 2019 at 5:04 am
Amine Ben Hadj Ali
Ansys EmployeeYou are using at least 2 fixed time step sizes. Please check in Fluent transcript if the behaviour is as your settings. You can report plot time step size too. -
October 15, 2019 at 9:20 pm
rafa08
SubscriberI have checked and the behaviour is as I am setting. My problem is the time step is always going down and it never increase eventhough the courant number is lower than 0.8. am i doing something wrong? in which cases i can used CFL based time stepping method?
I would expect time step to decrease, but once it stabilizes would hope it increase. why is fluent not updating the time step if the courant number is lower that 0.8?
October 16, 2019 at 5:03 am
Amine Ben Hadj Ali
Ansys EmployeePlease insert the plot of the time step size? -
October 18, 2019 at 8:09 pm
- The topic ‘Fluent – Time Stepping Method CFL Based problem’ is closed to new replies.
4602
1510
1386
1209
