Fluent – stops working when saving files
    • Marcin Nowak
      I got problem with a specific Fluent case (for other cases everything works), where I use "redistribute boundary layer" option.
      I cannot save case and data files, because Fluent stops working; below I present what I see in TUI for several hours. I have to use task manager to kill the process.
      I tested this saving files, on two computers, with the same results - Fluent stops working.
      The solving, convergence, exporting pictures, monitor files - everything works, just this saving case/data files...
      What can I do to solve this?
      Regards
    • Federico
      can you try writing the case file in legacy format .cas.gz?
    • Federico
  • The topic ‘Fluent – stops working when saving files’ is closed to new replies.
