August 21, 2024 at 5:27 pm
James Khreibani
SubscriberI have two streams of supercritical water feeding a species model as a NIST RG. One is high pressure, and one is lower pressure. I want to model the interaction between the high and low pressure streams. I can simulate the process using VOF which seems to be very computationally expensive and slow. I tried modeling as a species model but was informed that water could not be modeled as a mixed-species model (HP and LP) although the fluid conditions are identical. Is it correct to model through VOF or is there a better method?
August 22, 2024 at 10:04 am
Forum ModeratorVOF is for phase models where you track the free surface. Species is for a single phase where the materials mix. From your description if both streams are water in the same phase do you even need multiple species?Â
August 22, 2024 at 6:56 pm
James Khreibani
SubscriberThey are the same species however i want to model the interaction of the high pressure and low pressure and track how each stream behavies when mixed. In reality the high pressure may have some impurities but i want to keep the analysis simple to start with out mixed supecritical fluids which may not even be possible using the NIST Refprop database.
August 23, 2024 at 8:38 am
Forum ModeratorThe properties will be based on the cell conditions, so you can have inlets at different pressures & temperature. The complication comes with phase change and phase interaction, and it's not clear if you need to worry about that.Â
August 31, 2024 at 3:14 pm
James Khreibani
SubscriberThe specific error I keep getting: REFPROP_error (117) from function: setup [SETUP error 117] Estimation of mixing parameters is not possible for most mixtures containing water, hydrogen, neon, carbon monoxide, flourine, methanol, or ethanol.-
September 5, 2024 at 11:15 am
James Khreibani
SubscriberAny thoughts on this issue?
September 9, 2024 at 9:57 am
Forum ModeratorI had a week off. A mixture should use the averaged properties from the individual species, what have you set for the mixture?
5969
1307
