February 7, 2020 at 11:25 pm
JanM
SubscriberHello ANSYS community,
I've a problem with my fluent solver slowing down with an increasing number of iterations. I'm simulating a transient case of a vertical-axis-wind-turbine on my home computer, which has a Intel Xeon E3-1231 and 16gb RAM and ANSYS 19.1 (free student version) installed on a hard drive.
While this setup is probalby not ideal, the simulation starts fast with multiple iterations solved per second, but with increasing number of iterations the simulation then slows down. Last time I checked (around 10000 iterations in total), one iteration took up to 10 seconds to solve. My best guess is an issue with the memory (maybe?) but the task-manager actually shows that plenty of RAM should be available.
A work-around is stopping the simulation halfway through and restarting ANSYS, then it runs fast again. Sadly this is pretty time-consuming since FLUENT is, once the iterations slowed down, very "sensitive" to button-pressing i.e. freezes for a few seconds/responds slowly to commands. I hope someone has a fix for my (sometimes) lazy Fluent
Regards JanÂ
February 10, 2020 at 9:45 am
Forum ModeratorAre you writing animations? I'd also look at updating to 2019R3 or 2020R1 (should be available fairly soon as commercial release was last month).Â
February 10, 2020 at 10:34 am
JanM
Subscriber Hi rwoolhou,
currently I'm not writing any animations, that was actually one of my first steps too speed things up. I'm not even plotting any graphics/xy-plots or such, FLUENT only writes 3 files with moments and forces. An additional information, which might be important but I forgot in my inital post: I'm using the parallel solver on 8 cpus.
(PS: Since the computers at my university also still use 19.1, I have to keep the older version for now, too keep all data compatible)
Regards JanÂ
February 10, 2020 at 11:51 am
Forum ModeratorHow are you using 8core parallel? Should be capped at 4 for Student.Â
February 10, 2020 at 12:49 pm
JanM
SubscriberOh really? Didn't know that; as my cpu offers 8 cores I just selected "8" as FLUENT started, but judging the workload of the cores (according to the task manager) it actually uses all of them (also I didn't get an error as far as I can remember).
Nevertheless, since I'm running out of time a bit (self-inflicted, but that's another story
), I'm also using my old PC (AMD Phenom II X4 955 + 8gb RAM) and my laptop (Ryzen 5 2500u + 8gb RAM) to get some work done. They only have 4 cores anyways, so I'm using the parallel solver on 4 cores there, but I face the same problems with increasing number of iterations (the hardware is less potent for sure, but they also start rather fast and slow down with time).
Regards JanÂ
February 10, 2020 at 1:27 pm
Forum ModeratorOdd, I'll flag it this side. Â
Sliding mesh can cause a memory leak, typically Fluent's trying to track where everything is, but shouldn't cause anything to freeze. Files shouldn't slow anything up, but check where they're being saved in case you're tight on disc space.Â
To confirm, it's iteration time you're monitoring and not time step?
February 10, 2020 at 1:55 pm
JanM
SubscriberExactly, I'm monitoring the iteraion time which increases with increasing number of total iterations done; so to speak "the simulation slows down"
(my calculation is indeed a sliding mesh with a fixed time step and a maximum of 20Â iterations per time step, if convergence isn't reached)
February 10, 2020 at 3:29 pm
Forum ModeratorNot sure, I've not seen this reported on support so can't compare with other cases.Â
We know restarting works. Try re-partitioning too, read up on how message passing works (at a high level) in case that's a factor too.Â
September 22, 2020 at 9:26 pm
September 23, 2020 at 11:00 am
Forum ModeratorIf it's panels that are taking a lot of time check the graphics drivers and also RAMnJust noticed your other thread. Are you running remote via VPN?n
- The topic ‘Fluent solver slows down with time’ is closed to new replies.
5649
1885
1404
1303
