October 22, 2024 at 1:54 am
sampathsrikanth1999
SubscriberHello everyone. I am trying to run a 2-way FSI in an artery. I am simulating using 8 cores in our University's cluster. The solution, in the beginning, was fast. With progress in time, I found that the simulation slowing down and the reason appears to be the mesh update during the next time step. The mesh update and the data distribution to the fluent cores is taking so much time. Once it is done, the simulation runs quickly. Is there anything I could do to speed up the simulation?
October 23, 2024 at 7:34 am
Rahul
Ansys EmployeeYou may want to review your dynamic mesh settings or consider refining your mesh to accommodate the deformations better without requiring extensive updates. This could involve adjusting the mesh quality criteria or implementing local mesh refinement in areas of high deformation.
October 24, 2024 at 3:54 am
sampathsrikanth1999
SubscriberHi Rahul. I tried to implement what you said. I refined the mesh (Now I have 1 M cells running on 40 cores). I changed my dynamic mesh settings. Relaxed the remeshing settings. I have spring based smoothing (parameters set according to the reed-valve tutorial) and local face and local cell based remeshing. I also tried to activate implicit update (once in every 10 iterations with relaxation factor 0.5) but I don't see it getting reflected in the fluent transcript. The mesh update during the next time step is still taking too much time (approx 12 minutes). This update time is so slow when flow into the artery reaches the maximum. Do you have any other suggestions that I can try? Thanks in advance
October 24, 2024 at 9:59 am
Rahul
Ansys EmployeeThe solution might slow down with more number of cores. With increasing processors, the mesh and data will be partitioned and each core do its part of the work and interchange info (the compute node does this). So if the number of processors is high, communication time for the CPU will be more than analysis time which is not effective. Try using fewer cores for Fluent (10-15) as you have about 1M cells.Â
If it is Linux machine try clearing Linux File Cache buffers, you can include the
-cflushoption when launching Ansys Fluent from the command line to flush the cache buffers. -
October 27, 2024 at 2:12 pm
sampathsrikanth1999
SubscriberHi Rahul. I ran the case using 15 cores just as you said but I am still facing the same problem. The mesh update is so slow.Â
"COUPLING STEP = 111Â Â Â COUPLING ITERATION = 1". It gets stuck at this place. Its been 30 minutes(still counting). I also tried running a coarser mesh (140k cell in 2 cores). It also encountered the same problem. With time it got slower (it took 5 hrs to calculate 10 coupling steps (step size 1ms)). In the coarser mesh, I also encountered a issue that fluent is not converging. The fluent solution going well till now but now continuity is oscillating around 5e-3 (target 1e-4).ÂÂ
October 27, 2024 at 2:18 pm
sampathsrikanth1999
SubscriberÂ
A small update. I am confused with the output file.
COUPLING STEP = 111   COUPLING ITERATION = 1ÂUpdating solution at time levels N and N-1. done.ÂUpdating mesh at time level N...>> Dividing domain into 15 partitions using Metis.  Time = 0.0999391 seconds.  Done.ÂIt says the time taken was was less than 0.1 seconds. It took nearly 40minutes to output this line. What does this mean?
5824
