June 24, 2020 at 9:32 pm
Losiola
SubscriberHello ,
I am making a simulation using fluent , of course i run the simulation in parallel on 10 cores machine now the solution time is 2seconds.
also another workstation now is available which has better computational power 20 cores .so in case i reopen the case in this second workstation and initialize the solution using Interpolation values from simulation time 2SÂ Â than run calculation for 1 more second Can i say that i solved the case for 3s ?!Â
Kind regards
June 25, 2020 at 6:55 am
DrAmine
Ansys EmployeeOr you read the data file of first run and just continue calculation: both should work but I will prefer reading the whole data instead of interpolation file.
June 25, 2020 at 9:37 am
Losiola
SubscriberHI Amine,
is it possible to read the whole data file even it was generated for a simulation with 10 cores and my current one is gonne be with 20 cores ?
Kind regards
June 25, 2020 at 11:42 am
DrAmine
Ansys EmployeeYes.
August 15, 2023 at 9:41 am
Oluwagbemiga Fabunmi
SubscriberHello there, I just read a profile into ANSYS FLUENT using read-transient-table in the TUI section. However, when i try to intialize it brings up an error message saying " Get time interpolated value
August 15, 2023 at 1:03 pm
Forum ModeratorHave you set the solver as transient?Â
August 16, 2023 at 9:56 am
SubscriberYes I have. Eventually, I was able to resolve the problem. It seems when you input a profile as a txt file into ansys fluent, the heading of each variable must all be in lower case. When I changed this, the error of "get interpolated values" disappeared. Any thought?
August 16, 2023 at 10:07 am
Forum ModeratorMakes sense, Fluent is Unix based so will be case sensitive.Â
August 16, 2023 at 10:09 am
SubscriberCan I ask you another question? I am simulating flow through a porous medium using ANSYS Fluent. There is only one inlet and no outlet. However, when I view the CFD Post, I realize that the values for mass flow rate are all negative. This is strange to me because the vectors show that the flow is in the positive x direction as I'd set it up. Why are my mass flow rate values negative?
August 16, 2023 at 10:11 am
Forum ModeratorPlease can you post into a new topic. It makes it easier for others to find the topics when looking for answers.Â
August 16, 2023 at 10:15 am
SubscriberI already did. No one replied.
August 16, 2023 at 10:21 am
Forum ModeratorWhere? I can't see any new topics in your posting history
August 16, 2023 at 10:27 am
SubscriberDo you see any post now?
August 16, 2023 at 10:47 am
Forum ModeratorAs far as I can see you have not created a New Post in any of the sections I monitor, and there is no record of a New Post in the backend system. Please link, if you've added a comment to an old Post it's very likely that it won't be picked up.Â
August 16, 2023 at 10:55 am
SubscriberMy apologies. I just tried again. It was posted in the fluids page
- The topic ‘Fluent Solution initialization using Interpolation’ is closed to new replies.
5794
