Ansys Products
Ansys Products
Fluent simulation running slow when connected to internet
    • Bharanitharan_J
      I have Ansys academic research license under the student team category. I found that Fluent is running too slow even for simple 2D problems when connected to the internet and when the internet is switched off simulation speeds up. Can someone help me with this issue?n
    • YasserSelima
      Lucky you! mine crash when I disconnect the internet :)
      Assuming you're not hogging all the cpu and RAM watching YouTube, there shouldn't be a problem. If you check the system load what's taking all the cpu & RAM? Note, VPN can cause issues with the licence.
      YasserSelima try port 127.0.0.1 for the Fluent IP. In theory that stops the solver falling over.
  • The topic ‘Fluent simulation running slow when connected to internet’ is closed to new replies.
