Fluent scaled residuals
    • Hussein13
      Hello,I'm doing an aerodynamics analysis on vehicle using fluent.
      I completed calculations and got a very fair results.
      The problem is i couldnt find the iteration history for the scaled residuals, i saved the whole project and the fluent setup but i cant find the details anywhere.
      I managed to find the results for the CD and CL but the scaled residuals aee missing.
      Can anyone help?
      Thank you.
      P. S : a iteration history for the cd is attached and i want the same for the scaled residuals.
    • Amine Ben Hadj Ali
      Go under residual's and plot. I guess only last 1000 iteration are stored if you did not change the default behavior.
    • Hussein13
      Thank you amine Yes, i know how to plot the residuals. But the thing is i need the data which is used for plotting the graph, so i can use it in another program. I need it as a txt file or something similar,
      Okay. I do remember that writing option has been dropped. You need to initiate it from beginning. I need to check
    • Hussein13
      Yes, there is NO writing option for the scaled residuals. But, as d long as the fluent is able to plot it. Then the data must be there somewhere. I can't really do the calculation all over again. I would really appreciate if you could help me out.
      Thanks again.
      In Fluent console:
      1) /plot/residuals-set ptf then give a name for the file
      2) /plot/residuals
      Then select the equations which will be written in the file. You can then read back the file into Fluent to plot it or use elsewhere!
    • Hussein13
      In Fluent console:
      2) /plot/residuals
      I will give it a try and tell you what happens.
      Thank you sir.
      Please update then and mark the solution provided as the "answer" and the topic as "Is solved".
    • Hussein13
      Thank you sir.
      Anyway i can get the iteration's CP HISTORY, I have the Cd values but i only need the cp and the viscous coefficient as separate values not as a sum.
      Thanks again.
Viewing 8 reply threads
  • The topic ‘Fluent scaled residuals’ is closed to new replies.
