Fluent saving project fails
    • Mohamed Abu-bakr
      After finishing and when I attempt to save the project, during the saving process the following appears
      Writing "| gzip -2cf > FFF-Setup-Output.cas.gz"...
      Writing temporary file C:UsersuserAppDataLocalTempflntgz-62163 ..
      Node 0: Process 10132 signal SIGSEGV.
      Fatal error in one of the compute processor
      and the fluent exits with no solution available for CFD Post
      File 'D:xxxxxxxxxxxxxxTher 1m_filesdp0FFF-2FluentFFF-2.1-1-00105.dat.gz' does not exist or is not readable.
      I have tried to use the fluent standalone, workbench, reinstalling the software and updated version and all had the same issue.
      Are there any command (eg + % @) or non-English characters in the path? Also check write permissions to the folder.
  • The topic ‘Fluent saving project fails’ is closed to new replies.
