October 9, 2024 at 10:08 am
Joe
SubscriberHi. I have a simulation where I want to utilise the Runtime DFT capabilities to give me Fourier coefficients in the domain for different discrete frequencies. I am using the single tone runtime DFT option for static pressure at a single frequency (for testing purposes). For reasons I'm not clear on, following sufficient run time, the DFT results are zero for both magnitude and phase.Â
I suspect this may be due to the fact that when I run the calculation, I have a boundary condition that updates at every time step (following each time step, a new pressure profile is defined at one boundary). Would this implementation be a reason that the Runtime DFT option would not work correctly? Surely, if the data is still in memory (i.e. the simulation isn't closed during the runtime required), the DFT should still work. I'm wondering if anyone has any experience or suggestions?
Thanks in advance,
Joe
November 21, 2024 at 1:50 pm
Federico
Ansys EmployeeHow are you specifying the pressure profiles at each time step?
November 21, 2024 at 2:22 pm
Joe
SubscriberHi, Thanks for your message.Â
After each time step, I define a profile at the pressure outlet. In my journal file, this reads asÂ
"file/read-profile "location/*.prof"
 /define/boundary-conditions pressure-outlet outlet_boundary yes yes no pressure p no 284 no yes no no yes no 10 yes yes no no no solve/dual-time-iterate 1 10
 define/profiles/delete-all".I repeat these steps for the length of my simulation. The *.prof file is set up as specified in the example in the user guide.Â
I have also tried running the simulation for many time steps (longer than specified in the DFT setup menu) but still do not get data out of the Runtime DFT.Â
Thanks in advance,
Joe
November 21, 2024 at 2:41 pm
Federico
Ansys EmployeeInstead of reading .prof files, can you test the same case with a time varying Named Expression for this outlet_boundary? Just to check if this has any impact
November 22, 2024 at 12:25 pm
Joe
SubscriberHi - I have now tried this but still get zero's for all Runtime DFT output. Do you have any suggestions? Thanks
November 21, 2024 at 2:47 pm
Joe
SubscriberI will try. I have tried running the same case as above without the profile boundary (just a single-valued pressure outlet) for many time-steps and still get no data. This was a continuation of a time-varying simulation so will have included oscillations I'd expect to get data for.Â
5709
