Fluent restart calculation
    • Glibrary
      I am trying to restart my fluent transient calculation.
      As far as I know how to restart simulation is [file]-[solution files]-[recover missing solution]-[select the latest CAS file] and then select calculate again.
      I have saved CAS and CDAT files and tried to load the latest CAS file.
      But fluent shows an error that it cannot find the dat file when I tried to load the CAS file.
      Is it not able to restart simulation using CDAT?
      I have searched google and this community but couldn't find an answer.
      I would appreciate if someone teach me how to restart simulation.
      Thank you.
    • Keyur Kanade
      you should have cas and dat file.
    • Glibrary
      Hi kkanade
      Thank you for your reply!
      I will try it again!
      cdat is a cut down data file for post processing in CFD Post: you can't read it back into Fluent. Hopefully you've also saved some dat files too and that will allow you to restart.
    • Glibrary
      Hi rwoolhou,
      Thank you for kind explanation.
      I figured out the way!
Viewing 4 reply threads
  • The topic ‘Fluent restart calculation’ is closed to new replies.
