March 20, 2020 at 11:01 pm
jeong
Hello
I have faced a strange error when using report definitions and output parameters.
For example, when the calculation is finished, the mass weighted average of temperature gives very wrong value, as can be seen from the picture. Once I redefine it, have to change the variable from temperature to some other thing, and change it back to temperature, then it gives correct value. It is also reporting another "random" value to the workbench through output parameter. The error is not only happening to temperature, but also for some other energy variables, such as entropy.
The case was perfectly converged, and all the variable field looks reasonable. Only the report definition values are wrong. What could be reason behind it?
Kind Regards
March 22, 2020 at 7:32 pm
March 23, 2020 at 6:02 am
Keyur Kanade
Ansys EmployeeWhich version you are using?
Try latest version 2020R1.Â
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
March 23, 2020 at 8:14 pm
jeong
SubscriberKeyur
Thanks for the reply. I am using 2019R2, and this version is installed in university computers that I am working on. So, it will be difficult to switch to 2020R1 in a short time for me. Is this a bug? Any method I can use to go around this issue?
Kind Regards
March 23, 2020 at 9:55 pm
Karthik Remella
AdministratorHello,
Could you please attempt to reproduce this issue on a simple problem such as flow through a simiple pipe and verify if you are seeing this issue?
Thank you.
Best Regards,
Karthik
- The topic ‘Fluent report definitoin error’ is closed to new replies.
4633
1540
1386
1225
