August 11, 2024 at 3:21 pm
Saeed
SubscriberHello,
I have a question regarding the relaxation factor in fluent. I noticed that there is high order term relaxation in fluent/solution/method and there are relaxation factors also in fluent/solution/ Control . I wanted to know what is the difference between these two ?
Thanks
August 12, 2024 at 8:41 am
SRP
Ansys EmployeeHi,
Under-Relaxation Factors contains the under-relaxation factors for all equations that are being solved with the pressure-based solver
High order relaxation enables the relaxation of high order terms to aid in the solution behavior of flow simulations when higher order spatial discretization is used.
August 12, 2024 at 9:14 am
Forum ModeratorAnd to add both are explained in the Solver section(s) of the manuals.
August 12, 2024 at 8:35 pm
Saeed
Subscriberthank you for your reply.
unfortunately, I have an academic account and do not have access to them. i know that they should be decreased slighltly and need to be below 1. i would really appreciate it if you can explain how i can use both at the same time.
Thanks
August 13, 2024 at 9:08 am
Forum ModeratorIf you click on Help in Fluent you'll get straight to the User's Guide.
August 13, 2024 at 4:36 pm
Saeed
SubscriberThank you for your help,
I just have one more question, I know that for under relaxation factors , changing them to a lower value it needs less iterations but takes more time. I want know if the same thing happens for high order term relaxation ?
August 13, 2024 at 4:44 pm
Forum ModeratorMore iterations if you decrease the value. HOTR blends the discretisation scheme so may take more time but iterations required should be unaffected.
5719
