Ansys Free Student Software
Fluent R2 2022 application failed to connect, what should i do?
    • Jiaji Hu
    • Nikhil N
      Looks like you were able to complete the steps till the solution tab. Is this error coming up when you try to open the Results?
      Nikhil
    • Jiaji Hu
      Yes, it only happens when i trying to open the result on my win10 desktop. But when i send it to my win11 laptop, the result can be opened.
    • Nikhil N
      Can you try launching Results again after deleting ‘.cfx’ folder from this location: C:\Users\'username'\ ?
      Nikhil
      • Jiaji Hu
        I didn't find '.cfx' folder in this location.
      • Jiaji Hu
        here is the file all i have in that location
      You need to be able to see the hidden folders, there's an "AppData" folder in there too.
      • Jiaji Hu
        do you mean this cfx folder?
      No,    C:\Users\userID\AppData
      You did extract the zip, then install on C: whilst running as Admin?
      • Jiaji Hu
        I didn't install on C:
        inside C:\Users\userID\AppData, i search cfx is like this
      I think that's inside the installer zip. Where did you install the software?
      • Jiaji Hu
        In E:
      That may explain it. We've had problems with installs that aren't on C: with Student.
      • Jiaji Hu
        I have tried uninstall ANSYS and reinstall it on C: and still not work.
      Did you extract the zip, then install as admin?
      • Jiaji Hu
        yes, i did extract the zip, then install on C: whilst running as Admin
      Same error?
      • Jiaji Hu
        the same error
    • ONG CHUN HAU
      so have you solve the probelm? jiaji hu because i hv the seme problm as you
Viewing 10 reply threads
  • The topic ‘Fluent R2 2022 application failed to connect, what should i do?’ is closed to new replies.
